chalaging search.
Regular Member
chalaging search.
All,
As we all know in Pro E we have the option to add multiply models into
certain drawing.
is their any way to run search/sql script to get list of all related
models to specific drawing ?
Truth, it can be done manually, for each drawing, however I would like
to go over the entire DB (as part of DB improvement prior to PDM Link
migration).
Rami
Re: chalaging search.
> models into certain drawing.
> related models to specific drawing ?
This query should list drawing models (DGDEPTYPE=4) for drawing
'my_drawing.drw':
-- drawing models for a specific drawing
column parent format a35
column child format a35
select distinct
parent_pi.piname as parent,
child_pi.piname as child,
dg.DGDEPTYPE,
dg.DGDEPCOUNT
from
pdm.PDM_PRODUCTITEM child_pi,
pdm.PDM_DEPENDENCYGRAPH dg,
pdm.PDM_PRODUCTITEM parent_pi,
pdm.PDM_BRANCH parent_br,
pdm.PDM_PRODUCTITEMVERSION parent_piv
where
parent_pi.piname='my_drawing.drw' and
dg.DGDEPTYPE=4 and
dg.piid=child_pi.piid and
dg.pivid=parent_piv.pivid and
parent_br.brid=parent_piv.brid and
parent_pi.piid=parent_br.piid
This query should list all drawings that have multiple drawing
models (DGDEPTYPE=4) associated to them. Seems that this is
more what you were looking for:
-- drawings with multiple models
select
dg.DGDEPTYPE,
count(distinct child_pi.piname) as child_count
from
where
dg.DGDEPTYPE=4 and
parent_pi.pitypeid in (
select pitypeid from pdm.PDM_PITYPEDEF
where pitname='Drawing'
) and
group by parent_pi.piname,dg.DGDEPTYPE
having count(distinct child_pi.piname) > 1
The 'distinct' keyword in the 'select' and 'having' clauses
causes oracle to treat multiple occurrences of the same
drawing model as one occurrence. Eliminate the keyword and
you will get more results.
> would like to go over the entire DB...
You can do the above with Intralink Scripting in Java, much
more slowly, but the results will probably be somewhat more
accurate.
Marc
