I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.10
while creating a new configurable reference link as per the help center steps [Customizing Configurable Link Tables] the newly created link is hidden by the OOTB validator
Hi @MN_10720981
remove the filters (validators) from the customAction.xml configuration. or there where the tables are defined.
PetrH
Hi @MN_10720981
What is the question?
For configurable links you need to create own page tab with own table to show the links.
PetrH
Hi @MN_10720981
PetrH
@MN_10720981.. Check if following property was set ..
xconfmanager -p -s "com.ptc.windchill.enterprise.part.showReferenceLinksTable=ALL" -t codebase\wt.properties
