create document in folder
MikeLockwood
22-Sapphire I
Anybody seen behavior as shown in attached? Suggestions for why the difference?
Are you sure the composite OIR is the same? Your PPT did not show the create document GUI, do you have folder hard coded as a constraint normally? Only other thing I can think of is that the actions for New Document invoke different code in pre validation when the wizard UI is generated. An actions report or scanning XML might clue you in whether its a bug or not.
Sent from my Verizon Wireless BlackBerry
OIR for Folder in Library
[cid:image001.png@01CC5352.CF36A3B0]
OIR for Folder in Project
[cid:image002.png@01CC5352.CF36A3B0]
Yes, Different LC, but why would that affect?
Mike,
We are on 9.1 M060 and we do not see this behavior. It creates the
document in the folder where I select the New Document Actions menu.
Best Regards
Rajesh Balasundaram
