how can I create a report from
SITE --> UTILITIES --> Report Management
maybe I found the link of my interest ..
Link between EPMDocuments and WTParts (Tristan Owen)
but the link does not work !!!!!
The same QML report is attached to this discussion
and that I'm not able to do these reports ... can you help me create it?
Did you solved your problem and can give an explanation how you did it?
I would advice to create a select(all WTP) and subselect (WTP with EPMLink) then use operand Not In subselect and you can get the correct results.
I did similar report with MPMTools that are not linked to MPMOperations,
QML report is attached with WTPart not linked to EPM
(rename xml to qml >D.)
report has been created in Wch 12.0.2.0
PetrH
