We use the locked parameter in the model for "ptc_wm_created_by" to automate the drawing block for the "drawn by" value, when a user leaves the company and is deleted, all his released drawings now show the value as....... John Doe (deleted). This is without a check out or check in !!!. PTC says it requires a customization to fix it, it also displays it in Windchill for the "modified by" and "created by" columns. Now we have to go back to the old days of creating a model parameter like "created by" and then add it into the formats but this won't fix how windchill displays it.
This situation is one reason why PTC says it is better to deactivate accounts rather than delete them.The benefit to this approach is it avoids model/drawing/format parameter/relations changes and applies to all existing data, not just new models going forward.
http://www.ptc.com/support/usageassessments/windchill/). https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS102243
http://www.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=ParticipantAdminUserDeactivate&action=show
It really is a shame that PTC recommends deactivating accounts but doesn't provide the group or the filtering OOTB and only explains how to delete accounts.
