designer is already approver lifecycle
FC_9723361
9-Granite
Hello, i have a lifecycle for approval process. There are 3 approvers designated but one of theme is already a designer. How can avoid this? the designer should not be able to approve the object.
BenLoosli
(To:FC_9723361)
Remove that person as an approver? ☺
Is that designer allowed to approve other objects through that workflow?
Write custom code in the workflow that checks for the designer and if that person is also in the approver list, remove them from the approver list temporarily for that object.
Hello @FC_9723361
It looks like you have a response to your topic. If it helped to solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
