document rename not updating in task headlines
RR_10661622
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 CPS28
when user updated document with new name it not reflecting in the upcoming task headline but in the subject it does.
document rename not updating task headline.when user updated document with new name it not reflecting in the upcoming task headline but in the subject it does.
HelesicPetr
(To:RR_10661622)
Hi @RR_10661622
You could write a code to do so. Activation event is up to you if it is during a workflow or by listener that is activated during WTDocument rename action.
PetrH
9 REPLIES 9
olivierlp
Community Manager
(To:RR_10661622)
Hi @RR_10661622 and welcome to the PTC Community.
I'd suggest to add a reply to your own post with a few screenshots and details. I will help other users to engage and try to help you.
For reference, here is a guideline to help you: How to Ask a Good Question - PTC Community
Olivier
RR_10661622
(To:olivierlp)
RR_10661622
(To:RR_10661622)
observe the name that E24-025 not updated as E24-045 which is new name of the object.
Hi @RR_10661622 ,
As my suggestion simply you can try windchill shell : windchill stop then clear all the cache and logs  then start the windchill ,it will work
otherwise some thing issue in workflow task ,
and workaround you can try this (edit the DB side the subject text)  ! before you can try this test database !
Thanks & Regard
Sarathkumar M
Sarathkumar M
RR_10661622
(To:Sarathkumar_M)
Thanks for sharing your thoughts. But user will need to rename every time based on input from team so every time the object we can't edit manually in the db's.. Any other possibilities??
HelesicPetr
(To:RR_10661622)
Hi @RR_10661622
The point is that the task is generated on the start of the process and the task name is saved/stored
Change name of the WTDocument object does not update the name of the task and will never do it.
PetrH
RR_10661622
(To:HelesicPetr)
any customization possibilities to achieve it ?..
HelesicPetr
(To:RR_10661622)
Hi @RR_10661622
PetrH
Hello @RR_10661622
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
