document should not be sent to Publishing
DB_10822091
If I want a specific subtype of Document in Windchill not be sent to workers for publishing.
Where exactly we need to make changes in wvs.properties
this is causing two problems:
1. It is keeping AutoCAD workers busy during their execution which delays the others publishing
2. Failed jobs count is high in WVS job monitoring.
Please help me to find a solution for this.
BR,
Prasanna
6 REPLIES 6
BenLoosli
(To:DB_10822091)
Go to the Site-Utilities and select Publish and Thumbnail Control. In there you can block certain documents from being submitted to the publisher.
DB_10822091
(To:BenLoosli)
no no. I accepted as solution by mistake
But Its only for specific documents
I need that entire type of the document to prohibit publishing
I fixed that for you.
No its not yet.
I need where exactly we need to make this change. Where can i find the publishing rules? is it something we need to make this change in Wvs.properties (or) publishing rules?
This looks like a control assigned to specific document number/name vs. a document type. I am not the expert here, but it seems like a publishing rule needs to be created if you want to block a specific document type based on its type, state, etc.
We are working on this right now to stop all the failed jobs being cycled through the publisher for items that cannot be published like ECAD and Creo Material and Harness Mfg files.
Didn't we see this under a different post a few weeks back? So these AutoCAD files are handled via WTDocuments right? Have you tried looking at publishing rules?
https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/WVSPublishRules/WVSPublishRulesUsePubRules.html
