how do i file over modified workspace files with files from windchill cabinets? add objects? checkout/ with "reuse content" unchecked? I know I've done this before but I can't seem to get the right combo...
I just did a quick test using the embedded browser inside Creo. Here's what I found:
(I'm going to do this with text only because uploading dozens of pictures to this forum sucks...)
Object is modified locally but has never been uploaded (checked out or not)
Object is not checked out, modified, and uploaded
Object is checked out, modified, and uploaded
Note: This was tested with Creo Parametric 4.0 M060 and Windchill 11.0 M030.
It is possible to set a Windchill preference so "Apply to initially selected objects" is always checked by default.
