Hi @Boopathy
What do you want to suggest?
Please describe your issue clearly and provide some log file to see what's going on in the background process
I can just see that rename operation has been done, that's all.
PetrH
hi Helesic,
rename is not happening i got only this print alert.
You need to open method server log and check what is there in the log file.
folder on the server where WCH is installed ..../Windchill/logs MethodServerxxxx.log
PS> the link to original post is wrong. This one is correct > Windchill-Custom-Utility-Examples/
PetrH
i have attached the log
2023-09-19 13:57:44,221 ERROR [ajp-nio-127.0.0.1-8010-exec-6] wt.servlet.ServletRequestMonitor.request jayamukesh - 2023-09-19 13:57:44.217 +0530, nzyydow;lmkcq9p7;10220;fvgl2g;68156, jayamukesh, 172.23.0.181, /Windchill/wtcore/EPMRename.jsp, -, GET, 500, 0.0, 0.0036113
