get Err during approval promotion workflow
CHASEONHO
18-Opal
To change the status of a promotional target, we configured the following code:
wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice)primaryBusinessObject;
wt.fc.QueryResult qr= wt.maturity.MaturityHelper.service.getPromotionTargets(pn);
while (qr.hasMoreElements())
                    wt.doc.WTDocument doc=(wt.doc.WTDocument) qr.nextElement();
                    wt.lifecycle.LifeCycleServerHelper.service.setState((wt.lifecycle.LifeCycleManaged)doc,wt.lifecycle.State.toState("DESIGNCHANGE"));
try
wt.util.WTProperties props = wt.util.WTProperties.getLocalProperties();
VERBOSE = props.getProperty("wt.maturity.verbose",VERBOSE);
catch( Throwable t )
try{
     wt.maturity.MaturityServerHelper.service.unlockTargets (pn);
} catch (wt.maturity.MaturityException me){
       if ( VERBOSE )
         me.printStackTrace();
I got the following error:
wt.util.WTException: java.lang.ClassCastException: wt.part.WTPart cannot be cast to wt.doc.WTDocument
중첩 예외: java.lang.ClassCastException: wt.part.WTPart cannot be cast to wt.doc.WTDocument
중첩 예외: wt.util.WTException: java.lang.ClassCastException: wt.part.WTPart cannot be cast to wt.doc.WTDocument
wt.workflow.engine.FailedExpressionException: wt.util.WTException: java.lang.ClassCastException: wt.part.WTPart cannot be cast to wt.doc.WTDocument
I tried to promote the part object, but I get the following error:
I knew that if I ran this code on a part, I would ignore it and perform the original workflow.
But it was not.
What should I do?
Jason27
(To:CHASEONHO)
the primaryBusinessObject is a part object.
change
 to
wt.part.WTPart part=(wt.part.WTPart) qr.nextElement();
Dear Jason27
If so, does not the same error occur for WTDocument?
I do not know how to handle the API properly, so I have to apply the if statement to specify the lifecycle state only for the WTDocument and the rest to apply the original process?
I copied the original Approval promotion Request Process and assigned it as the default process.
Thank you.
