getting CR and CN number to appear in Assignments table view
jfrankovich
11-Garnet
Does anyone know if there is a way to get the assignments table to list the CR or CN number associated with a specific task? We use this to sort tasks by change number and keep assignments organized. Right now we manually embed the CN number in the Subject of the task, but that is tedious to do for every task and has the risk of errors.
John Frankovich
GSI Group LLC
www.gsiag.com<">http://www.gsiag.com>
[cid:image001.jpg@01CB2D72.393FDF40]
On my list of todo's also. This can be accomplished with a Data Utility
to change how the "Subject of Assignment" appears. The number should
appear at the end but with a change, it can be made to appear at the
beginning of that line by default. I've done the research on how to
create it but have not gotten to it yet. Once created, it would be a
small modification to the assignments JSP file to call out the data
utility. I do not believe there is another column that could be added.
Adding another column if it didn't appear by default would be a bigger
customization.
