Executing the rehost utility from command prompt for the clone scenario (WC10.2 test to prod)and getting an error- 'It is not valid windchill shell environment'.
Copied Source wc directory to target.(manually),So cant able to start the MS.
any thoughts?
Regards
Gangadharan.N
resolved this issue.
the source and target systems need to have the same file structure. copied to different file structure results this issue . ( ie D/ptc to E:/ptc). for clone file structure should match.
It is possible to clone a system to a different file structure. But, in that case you need to include the ChangeHome module in your scenario definition. Otherwise, if you don't include ChangeHome, then you're correct that the source and target need to have the same file structure.
Thanks Chris
Included ChangeHome scenario worked out.
