In the workflow process when task is assigned to multiple members and one of them accept this task i need to update some value on PBO. so need to know how to capture this event@
I'm not sure, but perhaps you can do it in WC11 with the Complete Task Transition in the Workflow Admin. Have a look in the help:
Thanks for the reply. i wants to update PBO before completing the task.
i got one solution as override the accept method which is called when we click on Accept Task.
