how to define report template to publish the results using a customized excel template
rsingaram
11-Garnet
Hi
I need to export the attributes of a particular "BOM part", it's associated attachments (like specifications, guidelines...) and it's BOM (if it is as assembly).
The sample format that I am attaching herewith.
I know that Report builder can generate  a nice report with all info needed. But from there to bring to this format, I need to build macros inside Excel.
But is there any document/method to take query report definitions and pass to some script to generate this report?
or directly (without going through query builder?).
Ravi
Take a look at this article.
https://www.ptc.com/en/support/article?n=CS162869
Marco
Thank you Marco.
But I want to Right Mouse Button menu click (of a BOM Part) from within Windchill UI and export.
I am looking for this function example (if any available) .
Alternately, I have already have configured a Report template (through report building). The export is a generic one showing all rows and columns. Is there any way to customize here to generate to custom xl format.
Thank you,
-Ravi
