I used to disable the alerts notifications (server sends a lot of alert mails "several <cache_nale"> may be oversized ) via the JConsole , and because , it is a test server ,which restart almost each two days , I have to disable the notifications each time . so My questionn is there a way to disable thos mail notifications in the wt.properties file ,through the xconfmanager command ? I guess if i use the below commad
xconfmanager -t codebase\wt.proeperties -s wt.mail.mailhost= -p olso the workflow notifcations will be disabled .
Thanks in advance.
How about just saving your changes in JConsole via Loader -> save()?
obsolete, related to my old account
