how to generate auto numbering with name sequence such as "MWEIP_IP_0001"..??
mnalla
7-Bedrock
Hi..
here i am providing the code that i have can you please rectify if it has any error
<!-- set the number to a generated number -->
<AttrValue id="number" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
<!-- add a prefix for variant parts -->
<Value algorithm="wt.rule.algorithm.BooleanBranch">
  <Value algorithm="wt.rule.algorithm.EqualsTest">
  <Attr id="genericType"/>
  <Arg>variant</Arg>
  </Value>
  <Arg>V</Arg>
  <Arg></Arg>
  </Value>
<!-- the sequence -->
<Arg>MWEIP_IP_</Arg>
<Arg>{GEN:wt.enterprise.SequenceGenerator:WTPARTID_seq:4:0}</Arg>
<AttrValue>
This should be fine.
BhushanNehe
(To:mnalla)
Hi Madhu,
Are you facing any issues with the modified OIR?
Bhushan
Hi..,
i found the error.
it is at the end of the code
</AttrValue> only.
