how to get related resulting change Notice form part
bshaik
3-Visitor
Hi ,
How to get related resulting change notices from parts. Please provide the syntax@
1 ACCEPTED SOLUTION
Hi Basha Shaik
You can try below API:
  • To query Affected by Change Notices use below API:
QueryResult affected = com.ptc.windchill.enterprise.change2.commands.RelatedChangesQueryCommands.getRelatedAffectingChangeNotices((Changeable2)prt);
  • To query Related Resulting Change Notices use this API:
WTCollection resulting = com.ptc.windchill.enterprise.change2.commands.RelatedChangesQueryCommands.getRelatedResultingChangeNotices((Changeable2)prt);
I hope this helps you.
Shirish
6 REPLIES 6
KD
(To:bshaik)
RelatedChangesQueryCommands.getRelatedAffectingChangeNotices((Changeable2)wtPart);
Kaushik
Hi Basha Shaik
Shirish
Hi Shirish,
To query Related Resulting Change Notices am using   getRelatedResultingChangeNotices((Changeable2)prt ) method and it working for me
Thanks for your Support.
Shaik Basha
SHARA
2-Guest
(To:bshaik)
Hi I am trying to get ChangeNotice from WTPart and getting Empty Collection please help me.
WTCollection changeNotice1 = (WTCollection)RelatedChangesQueryCommands.getRelatedResultingChangeNotices((Changeable2)prt);
logger.debug("changeNotice1 size :"+changeNotice1.size());
while(iterator.hasNext())
ObjectReference objectReference = (ObjectReference) iterator.next();
WTChangeOrder2 wtCN = (WTChangeOrder2) objectReference.getObject();
@_1647
7-Bedrock
(To:SHARA)
use below QUERY u will get ans --->>
WTCollection resulting = com.ptc.windchill.enterprise.change2.commands.RelatedChangesQueryCommands.getRelatedResultingChangeNotices((Changeable2)part);
System.out.println("\t Resulting Object by Change Notice size :"+resulting.size());
Iterator iterator=resulting.iterator();
arrList.add(wtCN);
System.out.println("Resulting object By Change Notice so CN Detils as below ----->>>> ");
System.out.println("\t Change Notice Name :"+wtCN.getName()+" & Change Notice Number Is "+wtCN.getNumber());
@_1647
7-Bedrock
(To:bshaik)
WTCollection resulting = com.ptc.windchill.enterprise.change2.commands.RelatedChangesQueryCommands.getRelatedResultingChangeNotices((Changeable2)WTPart / WTDocument);
System.out.println(" Resulting Object by Change Notice  - size :"+resulting.size());
System.out.println("Change Notice Name :"+wtCN.getName()+" & Change Notice Number Is "+wtCN.getNumber());
