Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Since "create" action default validator is DefaultUIComponentValidator. i created a validator extending it.
For "checkoutandEdit" action default validator is CheckoutAndEditValidator. i created another validator extending it.
PFA the java files. But the problem is that it works for create acton but not checkout functions.
Need help with this
Logeshwar.J
Can you attach the xml for the service and action?
Hi Jamie,
Sorry for the delayed response.
The property entry for the validators are as below
createPricolProduct - custom action name to create custom object
checkoutAndEdit - OOTB action name (used JcaDebug mode)
These property entries are added in the custom property file
<Service context="default" name="com.ptc.core.ui.validation.UIComponentValidator">
<Option cardinality="duplicate" requestor="null" order="0" overridable="true" selector="createPricolProduct" serviceClass="ext.pricol.common.validators.MultiValueValidatorCreate"/>
</Service>
<Option cardinality="duplicate" requestor="wt.part.WTPart" order="0" overridable="true" selector="checkoutAndEdit" serviceClass="ext.pricol.common.validators.MultiValueValidatorEdit"/>
</Service>
Logeshwar.J
You could try changing the requestor to "null". Also, I've had to add required="true" to the the action before. This document was created in response to a couple of cases I opened when I was having trouble getting validators to work.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS138656
Hope this helps. I'm out of ideas.
Hi Jamie,
Thanks for trying...But it is still not working...
Logeshwar.J
