importing a search list into Windchill/CreoView
dandersen
We have a list of about 200 drawings that we need to print out of Creo View. (At least most of the drawings are AutoCad drawings, if that makes any difference.) We have this info in an Excel spreadsheet. Is there a way to 1) at minimum use the spreadsheet to create a search in Windchill, and 2) preferably even to print the drawings from Creo View?
WC 10.0 Creo View 1.0
Thanks!
Donna Andersen
CAD Designer
Medallion Instrumentation Systems
17150 Hickory Street
Spring lake, Michigan 49456
Phone : 616-850-8018
Fax: 616-850-8097
donna.andersen@medallionis.com<">mailto:donna.andersen@medallionis.com>
[cid:image001.jpg@01CF5D83.3650AEF0][cid:image002.jpg@01CF5D83.3650AEF0][cid:image003.png@01CF5D83.3650AEF0]
Confidentiality Notice: This transmission and any accompanying documents or attachments contain confidential information from Medallion Instrumentation Systems LLC which is legally privileged, confidential and exempt from disclosure under applicable law. If you are not the intended recipient, or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution, forwarding, or copying of this communication is strictly prohibited. If you have received this communication in error, please notify the sender immediately and delete the original message. Thank you.
Can search all using a semicolon-separated list of numbers.
2345.DRW
3456.DRW
Needs to become:
2345.DRW;3456.DRW
[cid:image004.png@01CF5D75.2AF352A0]
One way to get a list into a semicolon-separated string is in Excel:
- Copy
- Paste special, Transpose
- Save as CSV
- Open the CSV file in a text editor; replace commas with semicolons
- Copy / paste the result into Windchill Number field
No solution that I'm aware of to print all
Once you have executed the search, (see Mike's suggestion)...
Copy the search results to your clipboard.
From your clipboard (Quick Links --> Clipboard), select all and choose Print in Creo View.
[cid:image004.png@01CF5EFA.DA935F80]
This is a nice bit of Windchill functionality that is often overlooked.
(You may need Creo View MCAD license for the bulk print functionality...)
Thank you to both Mike & Jered. You made my life a lot easier!
Donna Andersen
CAD Designer
This networking is really good for all.
Didn't know about the multi-select and Print from Creo View. Does this give options for paper size, etc., etc?
When I have used the batch printing in the past, it funnels all printing through Creo View which allows you access to the print driver for settings. If I remember correctly, you could print single or groups of items with different print settings.
Unfortunately, this option is not available for items published to PDF. (Eager to be corrected on this point... anyone, anyone?)
While we're on the subject, there is a batch print option from each context that can be run from the server instead of the client. See batch print in the help system.
All the best,
Jered
Ps. For the initial step of transposing a list of items from a column to a row, notepad++ has a command to join lines which handles this easily. Follow this up with find/replace... (this process can also be macro'd into a single command).
