I have a requirement that allow a role participant to modify CR at In Review state. The team member can only read at In Review state at policy ACL. The Role/ participants are not setup at context team. It is defined in CR's team template. So the role populates at the team in CR workflow process. So I use CR's lifecycle ACL to give the Role/participants (at the WF process ) the modify /modify content access. However still the participants can't modify the CR. Any thoughts or advice on where I am doing wrong.
