could you provide the structures that needed as to build a loader with its row for Part Number, and plantView, and DesignView, plus the target state is obsolete , I just want to get as similar example to how to build this loader structure it is a known knowledge of the loader as 50%
This does not make sense? Are you looking to create an import file for Parts via CSV2XML or are you using the spreadsheet import method? We need more details.
yes as to read from the csv file
