mdimpex() Time out problem
Level 1
Dear All,
I am using Pro/Intralink 3.3 / 2003290 and trying to import
objects from local folder using mdimpex() system command.
As soon as this command is executed, the return status
shows that it is done successfully ( no message appears)
After this I am accessing the objects in that workspace using
PDMLDBStartTransaction()
PDMLDBGetWorkspaceByName()
PDMWorkspaceGetWSPIByName()
PDMLDBCommitTransaction()
Though PDMWorkspaceGetWSPIByName() function returns 0, the WSPI handle is
NULL because after mdimpex() the object is not getting imported
It takes long time to physically get the objects into workspace.
I feel there is some time out problem with import/export in 3.3 as same code
is working fine for 3.2
This appln runs in batch mode
sequence is it imports the object and get into WS then execute some
operations
and then check in to CS
This works fine but after some objects are done with this it starts giving
this problem.
Regards
Pankaj Gupta
Tel : +91-040-27745566 Etxn : 5873/66
