modeler.bat file.. what is the fault in my bat file
Regular Member
I am trying to run modeler.bat file present  in the taskeditor but I am unable to execute it
the following lines are present in it.
set JAVA_HOME=<wt.jdk>
set WEB_INF=C:/ptc/Windchill_11.0/Windchill/codebase/WEB-INF
set MODELER_HOME=%WEB_INF%/../../taskeditor
set CLASSPATH=%WEB_INF%/../;%MODELER_HOME%;%WEB_INF%/lib/ieWeb.jar;%WEB_INF%/lib/jmxcoreWeb.jar;%WEB_INF%/lib/ie3rdpartylibs.jar;%WEB_INF%/../../lib/servlet.jar;%WEB_INF%/lib/mail.jar;%WEB_INF%/lib/activation.jar;%WEB_INF%/lib/install.jar;%WEB_INF%/lib/wncWeb.jar
start %JAVA_HOME%\bin\javaw com.infoengine.modeler.UI.IEModeler -web_inf "%WEB_INF%"
regards,
madhu
Tags (2)
Re: modeler.bat file.. what is the fault in my bat file
Set the path for wt.jdk as well. For some reason, the installed doen't build the paths in this bat file.
This is my WC11 file
set JAVA_HOME=D:/ptc/Windchill_11.0/Java
set WEB_INF=D:/ptc/Windchill_11.0/Windchill/codebase/WEB-INF
ThankYou for the reply. Now am able to start it.
BR,
madhu
