more date parameters questions
TracyWillis
&PTC_WM_CREATED_ON
&PTC_WM_MODIFIED_ON
When I look at values for these date parameters above in my parameter list they each show a different date...Which is correct. They are different...as most of them would be.
*BUT - When I enter these parameters into a drawing note they both display the created on date.
Even though the modified on date is different.
Also - The modified on date doesn't update anymore. I started using this last week and I'm pretty sure that field would update & should the date of the previous check-in each time the drawing was checked out.
What could cause these dates to display the same date even though they are different dates in the parameter list?
Mr. Tracy Willis
Unless you are appending the ":d" for drawing parameters, it is pulling the MODEL parameters, not the drawing parameters - could that be the issue?
Thanks Kevin
That was it !
Colon D
I didn't imagine that it would behave that way since the source of the parameter was listed as Windchill.
BUT - It makes since now though... the drw and the ASM have the same parameter names for those dates.
