I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS16
unable to upload CAD model.
The error message says, name has an upper limit of 200 characters.
According to PTC, Name is defined as a "short description".
Are you really entering a short description or a long description?
The upper limit for Name is 400 characters. If your system is set to 200 characters, there is probably a good reason for it. For example, Name gets passed to the ERP system and the ERP "Name" field is limited to 200 characters.
If you are the business administrator and there are no external drivers on the 200 character limit, then this article says how to extend the length of the attribute to the 400 character limit.
https://www.ptc.com/en/support/article/CS406025
Name is not a Global Attribute and is tied into the Workgroup Manager. Too much can go wrong by extending it's max length.
If Name goes beyond 400 characters, I would recommend creating/using a Global Attribute (e.g. DESCRIPTION). Global Attributes (a.k.a. IBAs) have a max length of 4000 characters.
the 200 string length constraint is locked, i have created a new one but it does not help:
This is a database column constraint. There was an discussion about someone wanting to increase this a few days ago:
https://community.ptc.com/t5/Windchill/how-to-extend-name-field-of-WTDocument/m-p/921801#M77106
BTW, the image you showed filename. That is not the same as name field which is more for descriptive or a object's title.
Don't recommend you muck with this. 200 characters is more than an old style tweet. @mmeadows-3 is right that if you want to write a novel, use an IBA.
Thanks for your response, we did the same thing of renaming the name and file name, its now much less than 200 characters, still we get the same error, is it due to child parts having long names or long folder name?
If child parts are getting checked in at the same time, yes, they could be the issue. Folder should not be an issue as its not part of the name field. To isolate the issue, you can try checking in items one by one, moving up the structure. Or look in the workspace name field column. Any name that looks really too long, you can flag. You should be able to export the contents to excel, do a length check and narrow down the offending items.
Something also to consider when increasing the default column widths or using very long names is how they display on pages and in the interface. Columns are set to cut off the value with a ... if it gets too long. So users are not going to even see most of the text. Its still there and can be filtered on but most of it is cut off unless you make the columns of that page very wide. You want to make sure you do not have any issues displaying fields where it can muck up the UI.
