need to propagate three properties from xconf
krthk86g
hello PTC. i would like to propagate the following properties from xconf to wt.properties.
wt.queue.executeQueues=false
wt.manager.monitor.services=MethodServer BackgroundMethodServer
wt.manager.monitor.start.MethodServer=1
BenLoosli
(To:krthk86g)
Run xconfmanager with the -p command, propagate.
If you don't know this, are you qualified to be making this level of change to Windchill?
krthk86g
(To:BenLoosli)
Hi BenLoosli,
Sure I am aware of the xconfmanager propagation. I would be grateful if I get to know the right tag in xconf to populate.
not able to position the right tag in xconf to populate to wt.properties.
Karthik
AndyHermanson
(To:krthk86g)
It would look something like this:
xconfmanager -'wt.queue.executeQueues=false' -t codebase/wt.properties
xconfmanager -s 'wt.manager.monitor.services=MethodServer BackgroundMethodServer' -t codebase/wt.properties
xconfmanager -s 'wt.manager.monitor.start.MethodServer=1' -t codebase/wt.properties
