parts/asm cannot be retrieved
ptc-5498144
hi
I am having trouble retrieving data from windchill, followed by the massages bellow :
1. The object with the following key was deleted or inaccessible: "wt.epm.EPMDocument
2. Local cache for source "failedRequest" is having incomplete information for merge
3. Local cache contents need to be synchronized with the workspace
does enyone have en idea what could be the problem and how to fix this?
Having the same issue and cannot figure out a solution.
You can run the below command and check the actual location if the file exists there.
Know the Physical Location
windchill wt.fv.tools.WContentVerify -checkBusinessObject
Hello Arpit,
I'm not familiar with "wt.epm.EPMDocument". Could you describe it more clearly? Thanks!
doehr
(To:段輝)
Hi Hui Duan,
That's the internal object type name for a CAD file in Windchill.
As for the original post, could it be an access rule thing? Do you have proper access to that file?
PS: I have no idea why it is blocking your name.
