possible to revert back CPS
Rahul_Rathore
7-Bedrock
Is it possible to revert back CPS installation to the previous one?
I am using the windchill 11.1 MO2O CPS16  on my local workstation and updated the CPS 18, after some time i realized that CPS16 was better than CPS18. So i want to revert back to CPS16?
Can i do that? What would be right options or steps to do that?
I am sure there is no undo. Curious as to what is so bad that you would want to rollback? I would also note that you should be considering upgrading at some point since 11.1 is off support.
The only way I would see to roll back would be to restore a snapshot or back up of the entire system. Each update or upgrade should be done with a restore point if something goes wrong.  The problem is that you mentioned it has been some time. This means that you've likely been in operation creating new data. I do not think those things are separable so unless you also roll back vaults, DB, LDAP to a common sync point, I think its too much effort. Sorry for not so good answer.
Hi @avillanueva
Thank you so much for your guideness.
Your suggestion is ready helpful. So i will try to update or upgrade.
Thank You...!!!
