I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.1
we are not able to activate a new or an existing ditribution target on our systems (DEV and PRD).
The article
https://www.ptc.com/en/support/article/CS342745 says the issue should be solved on version 12.1.2.1, but we still have the problem.
Here are the errors that I faced
ATTENTION: il file "D:\ptc\windchill12\windchill\codebase\com/ptc/windchill/esi/ESIResponseMetaInfo.xml" non contiene l'elemento informativo sul gruppo con nome logico "DeletedSCCResourceLinks"
