queue job going crazy
Mat
Hi there,
I have a problem with a job in "commonScheduleQueue".
This Job runs for at least half an hour and fills up the transaction log on my database completely (meanwhile 30GB).
The job's details:
  • Target Class:
    wt.scheduler.StandardSchedulingService
  • Target Method:
    executeScheduledItem
  • Arguments:
    [object: wt.scheduler.ScheduleItem:13000302, type = class wt.fc.ObjectIdentifier]
How Do I identify, what the corresponding issue is?
I mean, if "13000302" corresponds to a (e.g.) promotion request, that is already closed, I could simply delete this Job. But currently I just do not know.
Chears /me
HelesicPetr
(To:Mat)
Hi @Mat
go to a database and perform a select
select * from WindchillDB.ScheduleItem where ida2a2='13000302' (this is for MSSQL)
You can find interesting information in a itemDescription, itemName or different column which can help to identify the schedule operation.
here is just example of one row with headers
administrativeLockIsNull typeadministrativeLock cancelled classnamekeydomainRef idA3domainRef immediateMode inheritedDomain itemDescription itemName measurementUnit nextTime periodicity principalRefIsNull classnamekeyA5 idA3A5 classnamekeyB5 idA3B5 queueName runCount securityLabels startDate targetClass targetMethod createStampA2 markForDeleteA2 modifyStampA2 classnameA2A2 idA2A2 updateCountA2 updateStampA2 toBeRun
NULL NULL 0 wt.admin.AdministrativeDomain 9 0 0 Clean up of unreferenced filevault items purgeUnreferencedFvItems 0 26:58.0 86400 0 wt.org.WTUser 12 wt.queue.ScheduleQueueEntry 14226613 commonScheduleQueue 2 NULL 27:07.0 wt.fv.StandardFvService purgeUnreferencedFvItems 27:15.0 0 16:31.0 wt.scheduler.ScheduleItem 14226612 6 16:31.0 -1
Some information could be helpful.
PetrH
Mat
(To:Mat)
oh, I forgot to mention.
After the job is "done" (or just crashes, who knows), it is rescheduled for the next day.
HelesicPetr
(To:Mat)
Hi @Mat
PetrH
Mat
(To:HelesicPetr)
Thanks @HelesicPetr
I get this result.
administrativeLockIsNulltypeadministrativeLockcancelledclassnamekeydomainRefidA3domainRefimmediateModeinheritedDomainitemDescriptionitemNamemeasurementUnitnextTimeperiodicityprincipalRefIsNullclassnamekeyA5idA3A5classnamekeyB5idA3B5queueNamerunCountsecurityLabelsstartDatetargetClasstargetMethodcreateStampA2markForDeleteA2modifyStampA2classnameA2A2idA2A2updateCountA2updateStampA2toBeRun
NULLNULL0wt.admin.AdministrativeDomain810NULLLogTableCleanerScheduledTask32022-08-29 22:00:00.000000010wt.org.WTUser11wt.queue.ScheduleQueueEntry13000303commonScheduleQueue24NULL2022-08-03 22:00:00.0000000wt.method.jmx.LogTableCleanerpurgeOldEntries2022-08-02 11:13:13.000000002022-08-29 08:00:45.0000000wt.scheduler.ScheduleItem13000302502022-08-29 08:00:45.0000000-1
I found this Case https://www.ptc.com/en/support/article/CS178198
I will give it a try.
