We Have one Customized serach...
Normaly We make a Customized Softtypes of WTDocument .
As exm.
- In Type And Attribute Manager
* Document
* Customized Type
* Customized Doc
* Customized EPMDoc
When we Select"Search Type = Customized Type" with Created By Criteria in Critea field.. It gives only Docs in result, but when on same search page we change the serach criteria from "created by" to Other like"created On" it will gives us EPMDocs and Normal Docs in result set..
Its only not Working on "Created By " & "Modifyed By" criteria... all other criteria works fie..
One Another thing.. when i select Exclusively Search Type as" Customized EPMDoc" and in search Criteria"Created By", it not gives any result.. but when i remove "Created By" criteria it will gives results..
Anyone knows where to to changes to gives result for "created By " Criteria Which gives us both EPM and WTDocs in result set of Customized Type
Any Help will greate..
Vivek
Be aware that Created by only gives you the creator of the most current revision, not the original creator of the file.
Hi Domingo,
Thanks for Reply, but in this case it not showing any results by Criteria" Created By".
For WTDocuments - Gives Result
For EPMDocuments - Gives Result
For SoftTypes of WTDocuments (in case of WTDOC) its gives result, but we create Same way Softtype of WTDocments foe EPMDocuments.. It not gives serach result only for Criteria" Created by".
Other all criteria is works good on all Types.
Vivek
