"Modified by" condition in Query Builder
FelipeOliveira
2-Explorer
Dear,
Can I make a condition in the query builder to bring me only documents modified by a particular person?
There is no Colunm "Modifiedy By".
Thank You.
Felipe.
Hi Felipe,
Here is an article that shows an example on wtpart doing a similar function.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS176778
Notice it is important to select from wtdoc, the wtdocmaster, and wtuser.
join doc with masterReference to docmaster
join doc with modifier to user
Then you will be able to add the condition desired.
Thank you,
Jarrett
Hi Felipe,
Thank you,
Jarrett
Thank you Jarrett.
Felipe,
here in the community I wrote a document about reporting, which collects information from many sources (the article posted by Jarrett is already in this document).
http://communities.ptc.com/docs/DOC-6348
You can also join this group: http://communities.ptc.com/groups/reporting
And maybe vote up this two ideas:
http://communities.ptc.com/ideas/4634
http://communities.ptc.com/ideas/4659
Marco
