removing default attrıbutes from the layout creation screen
fatihsimsek
When I create a new document type in Windchill's Type and Attribute screen, there are default attributes that appear in the Create Layout screen. How can I remove these attributes from the layout screen?
Fadel
23-Emerald I
(To:fatihsimsek)
This attributes are Inherited from a patent type , they can be removed from there .
Otherwise you have to create layouts for that subbtype, Creating a New Attribute Layout
Do Not do this diretcly on a prod sytem , before fully validating on test server
Fede
6 REPLIES 6
Fadel
23-Emerald I
(To:fatihsimsek)
Fede
fatihsimsek
(To:Fadel)
Thank you for your support
HelesicPetr
(To:fatihsimsek)
Hi @fatihsimsek
As @Fadel mentioned. You have to remove all attributes from the root type layout and then specify the attributes on each sub type layout.
PetrH
Fadel
23-Emerald I
(To:HelesicPetr)
if these attributes are needed in other sofrtypes we may try to hide these attributes visibilty on that specific type :
Fede
Hi @fatihsimsek,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
