removing product
jblittle4
removing product
Forgive me if this has already been asked before but is there a way to remove product from the product side in PDMLink?
Any help is greatly appreciated!
Thanks!
Delete or move everything in it. Folders..everything.
Delete any configurations specific to it. ACL's, domains etc.
If there is no way to do it in the UI, view details page of product and write down the number for the oid. You can use that to open a database
Connection to say something like delete from pdmlinkproduct where ida2a2=oidnumber;
commit;
Since its part centric all otherdata will follow your business data and not reference the product.
Good luck.
Sent from my Verizon Wireless BlackBerry
sathimuthu
(To:ddemay)
i provided the oid number . it asked me to give the u8 value . i gave . but it says error at line 1 , missing expression. what to do ?
If you don't want to mess with the database, then once you've "cleaned out the product", and removed all Team members, you can simply create a deny all policy rule for the product's domain. It will still be in the db, but no one will be able to see its existence.
Russ
