hello
i would like to add object history into selection/constraint ?
Ex : Change History
Regards
Please can you change the browser language to English, because it is impossible for you not to have the last modification date since it is a STANDARD attribute of Windchill.
Then, having done that, verify that the table you put in the report is the correct one.
In my case it has this internal name wt.lifecycle.ObjectHistory
Having done that I wouldn't know what else to suggest.
Take a look at this article
How to generate a report to display the Maturity History of an object
Hello Marco
I suppose, i have not selected the good attribute
but i have not found an attribute named « promoted date »
please see attachments
Regards
You have selected the state not the date.
Try the attribute highlighted in yellow
Marco
you say I have selected the state not the date
where do you see that ? here down it seems i have selected history.modifyTimestamp
i tried to select History.Last modified but i can't find it
You have to select this table
And this attribute
Hello Marco
your response is clear but as i said upper i can't find "Last modified" into my Object History
