ref: CS22167
From Org, Groups UI, one can see all members of each Group. There is no way to output this to a file. Cannot get info using any Windchill report.
Has anyone solved this problem (found a way to export Group membership to Excel)? We're required to periodically audit membership and this would be very helpful.
Hi Guys ,
I believe it is possible , I would suggest to create a Document Link in Library and pull a report hitting the WTGroups (DB) and pcking up users from the Groups with WC APIs.
It should work.
regads.
Sriram Rammohan
We paid a consultant for a Windchill shell-based tool – works perfectly.
Hi Swamy.
Could you tell more about this command line?
