Hello @bdursunkaya-2
I don't know if it is possible to do so.
Try to download a importable Spreadsheet with a Secirity Label.
Create a WTPart and set a Security Labels then export it to the importable Spreadsheet.
If the security labels will be in the Spreadsheet then it is possible to import it and you will have the example.
If you are not able to download the security labels to the importable Spreadsheet then It is not possible to import it by the Spreadsheet in my opinion.
PetrH
Here is an example:
Note that Security Labels are a single string in the database. So what you see is my label, "EXPORT_CONTROL" and its value after equals sign. The next column is an IBA for "USMLECCNCADCODE". Ensure that the security label column has "Security Labels" as its column header. You can use the standard Part import via spreadsheet.
Have you found a way to set the labels back to null with this method?
What object types are you looking to load? Only parts/docs support load from spreadsheet. Here is the documentation on it...
If you export an importable spreadsheet on objects where security label values are null, the spreadsheet excludes the security labels column. You will have to add it manually. Where [SL_IV1].. IV2 .. IV3.. is the internal value of the label NAME.
So for example if you had a security label Corp Proprietary with an internal name of CORP_PROP and values of YES, NO and then a multi value Security Label Security Code with an internal value of SEC_CODE and values of RED, GREEN, YELLOW, NO your cell would look like this:
CORP_PROP=YES|SEC_CODE=RED
There does seem to be a limitation where you can't set a value to null (set something that has a value to the null / no value.
| Security Labels |
| Security Labels |
| [SL_IV1]=YES||[SL_IV2]=YES||[SL_IV3]=YES| |
