i would like to understand the "shared team" concept in Windchill
regards
Laurent
A shared team is essentially just a team (roles, members, users) that can be used in multiple contexts and managed from a central location.
For example, you have "Example Organization." Under this organization, you have "Product_A," "Product_B," and "Product_C."
You have 75 users in 6 different roles who will be working on both "Product_A" and "Product_B."
You have 3 options:
1.) Create Product_A, go to the Team page, add the roles you need. Populate those roles with the 75 users you need. Then, create Product_B and do the exact same thing all over again.
2.) Create Product_A, configure the team accordingly. Save Product_A as a template, and then use that template to create Product_B.
3.) Create a shared team ("TEAM1") at the organization level. Configure it with the 75 users and 6 roles. Then, when you create Product_A and Product_B, select TEAM1 to use as a shared team. The context teams are automatically populated with all the roles/members configured for TEAM1.
There are a few benefits to using a shared team:
The potential drawback is that you can't remove shared team members on a context-by-context basis. For example, "Sally" is a member of TEAM1. However, you don't want Sally working on Product_B. In this case, you must remove Sally from TEAM1, and then add her to Product_A and Product_C as a local member
For more information, see the Windchill Help Center: http://support.ptc.com/cs/help/windchill_hc/wc102_hc/TeamSharedTeamAbout.html
Thank you very uch for this answer
just a clarification: "75 users in 6 different roles..."
what are the 6 corresponding roles ?
regards
Laurent
The 6 different roles was just a random number I picked. It might be 1 role or 12 - I was just trying to illustrate that some teams are complicated and difficult to configure.
