the handle is invalid Windchill
MS_Santos
I have a problem with a shortcut on the server machine that should execute the following command
C:\ptc\Windchill_13.0\Windchill\bin\windchill.exe -w “C:\ptc\Windchill_13.0\Windchill” --java=“C:\Program Files\Amazon Corretto\jdk17.0.12_7\bin\java.exe” shell and it shows
HelesicPetr
(To:MS_Santos)
Hello @MS_Santos
I would recommend to use different place for java JDK.
The C:\Program Files\ is very strict area, and I have experience similar issues if the JDK is placed there
Does not matter that you run it as an Administrator.
So install/move the JDK to different place then C:\Program Files\...
PetrH
7 REPLIES 7
Is Java still in that location?
MS_Santos
(To:jbailey)
When you say this location, is it the Windchill server? If so, yes
Just verifying that the file path to java is the same as what you have in your command
MS_Santos
(To:jbailey)
It's strange that after trying several times, it connects fine.
VR_4000
(To:MS_Santos)
It may be a conflict on java itself, if you have multiple versions installed, try uninstalling all java, restarting the computer and then installing only one java.
HelesicPetr
(To:MS_Santos)
Hello @MS_Santos
PetrH
Hi @MS_Santos,
Anurag
