these PRT's do not have same neutral data version as the generic CAD Part - xxx.prt and hence c
vmcdaniel
Has anyone seen this issue and have a resolution for me? PTC TS cannot seem to figure it out and I have found no published results from any searches.
I check-out and modify the instance and attempt to check in all the instances and generics and the Check-in fails with this message.
Instance(s) [CAD Part - 86277410.prt, 1.10, CAD Part - 86276350.prt, 1.33, CAD Part - 86275110.prt, 1.33, CAD Part - 86276690.prt, 1.13, CAD Part - 86277500.prt, 1.5, CAD Part - 86276280.prt, 1.33, CAD Part - 86276360.prt, 1.33, CAD Part - 86276340.prt, 1.33, CAD Part - 86274180.prt, 1.34, CAD Part - 86276060.prt, 1.34, CAD Part - 86276710.prt, 1.33, CAD Part - 86277030.prt, 1.16, CAD Part - 86277280.prt, 1.12, CAD Part - 790879.prt, 1.10, CAD Part - 86277450.prt, 1.8, CAD Part - 86276330.prt, 1.33, CAD Part - 86276070.prt, 1.34, CAD Part - 86276320.prt, 1.34, CAD Part - 86276530.prt, 1.33, CAD Part - 86276870.prt, 1.19, CAD Part - 86276960.prt, 1.15, CAD Part - 86277130.prt, 1.13, CAD Part - 86276950.prt, 1.12, CAD Part - 86277470.prt, 1.7, CAD Part - 86274950.prt, 1.33] do not have same neutral data version as the generic CAD Part - scr_carriage.prt, 1.37 and hence cannot belong to the same family table.
I've attempted to 'break up' the family table, check-out old iterations and have not been able to get this change check-ed in
Thanks!
Vaughn
Vaughn,
I discovered the same problem with a hardware family table about 3 weeks ago. Tried many of the same things but to no avail.
There is a tech support document that covers this (CS45053) but it offers no workaround other than the correction being in WC 10 M040 and 10.1 M010.
John Frankovich
GSI Group
www.gsiag.com<">http://www.gsiag.com>
Sorry for the typo on this one. The document is actually CS45052.
