thumbnail 생성 중 서버 메모리 부족이 발생하여 windchill 서버가 중단
dhkim
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.5
thumbnail 생성 중 서버 메모리 부족이 발생하여 windchill 서버가 중단되는 현상
Catalina
Moderator
(To:dhkim)
Hi @dhkim
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Does the memory issue occur with all thumbnails or only specific file types or sizes?
  • Are there any custom thumbnail generation settings or scripts in use?
  • Is the issue reproducible on demand, or does it happen intermittently?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
dhkim
(To:Catalina)
Hi Catalina,
Thank you for your response and helpful guidance.
To provide more details, the memory issue occurs specifically when generating thumbnails for certain CAD files. As shown in the attached screenshot, the pvsthumb.exe process consumes an excessive amount of memory during thumbnail generation, eventually leading to a Windchill server shutdown.
This issue appears to be isolated to specific CAD files, rather than occurring system-wide. We suspect that it may be related to the complexity or size of the CAD models involved.
Could you please advise on how to address this issue? For example:
  • Is it possible to limit the memory usage of pvsthumb.exe?
  • Are there any best practices for generating thumbnails from large or complex CAD files?
Thank you again for your support. I look forward to your suggestions.
Best regards,
@dhkim
Catalina
Moderator
(To:dhkim)
Hi @dhkim
Thank you for your question.
Best regards,
Catalina
PTC
ScottMorris
(To:dhkim)
i would strongly suggest diagnosing this issue with PTC Technical Support. you need to provide them with a breakdown of you installation and configuration to better understand why this is happening.
i always run cad workers and thumbnail generators on their own computer and not the server running Windchill.
