When i try to move an object it gives me this error. It's location shows up as being in one of my personal cabinet. Part of the problem is that it is checked in.
"CRITICAL ERROR: this object is in a personal cabinet. Objects in a personal cabinet must be checked in before they can be moved."
Currently using Wildfire 4.0 m210 with windchill 10.0 M020
Thank You
Donald
Is there any Windchill API to find out if Object is in personal cabinet. This will help me to handle such type of objects while bulk moving of objects.
I believe there is a WinDU and WinRU task to fix those.
I would open a Tech Support call with PTC. Sounds like currupt workspace. Your workspaces are all part of your personal cabinet. If the object is in check-in state, but when you try to move the error states it needs to be checked-in, this indicates an anomoly in the database. Tech Support can help you get it sorted out. /pete
