unable to delete ,menufecturing WTpart
Sandy7
i am trying to delete E.1 version of menufecturing WTpart part which i revised by mistake but while deleting it is showing an error "Referential integrity violations occurred for this operation:
Object "Release Activity - com.ptc.windchill.esi.txn.ReleaseActivity:136xxxxxxxx" references the object "Part - Wxxxxxxxx, xxxxxxxx,D.1 (Manufacturing)" that was removed from the system."
could you please help.
Br,
Sandeep C.
avillanueva
23-Emerald I
(To:Fadel)
Depending on your level on integration with ERP, these tables are important for allowing Windchill to keep track of what its sent over before. However, if your goal is to delete, then this article is safe to follow. Make sure the revision in your ERP system is good as well.
7 REPLIES 7
avillanueva
23-Emerald I
(To:Sandy7)
You are blocked since it was published via your ESI integration. Check the Enterprise Systems transaction manager for that part and see if its listed. It is possible to remove those transactions but will allow the version to be deleted.
Sandy7
(To:avillanueva)
Could you please guide me where to check ESI trasection manager for the part?
avillanueva
23-Emerald I
(To:Sandy7)
Its on the Site - utilities page. You need to be the site admin to see that. Your system is integrated with an ERP system right? Your admins need to be engaged to remove this.
Sandy7
(To:avillanueva)
you are right. it is published to the ERP system. what can be done to revert it back?
Fadel
23-Emerald I
(To:Sandy7)
avillanueva
23-Emerald I
(To:Fadel)
Sandy7
(To:avillanueva)
thank you guys. the article is really helpful.
Br,
Sandeep C.
