verification method
MINGRUJIANG
verification method
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS03
Does the login system authentication method support radius?
If yes, how to enable it?
Translated the below text from Traditional Chinese to English using google translate on 17th April 2023 at 13:57 Hrs IST. Translated by vnamboodheri
Subject: 認證方式
Body: 登入系統認證方式,是否有支持radius?
若有,如何啟用?
HelesicPetr
(To:jbailey)
Hi @jbailey
it is true that PTC does not support the radius, but Apache can be configured to use it
https://techexpert.tips/apache/apache-radius-authentication-freeradius/
it is similar if you need to set SSO with 2fase authentication for Windows account,
It is out of the scope of PTC support
PetrH
It does not
HelesicPetr
(To:jbailey)
Hi @jbailey
PetrH
