Are you using WindchillDS or another LDAP for your user authentication?
Do you have a backup of your authorization files that could be restored to recover the settings?
Do you have a DB administrator who can look in the DB and see what the permissions are for the wcadmin user and possibly reset them that way?
Not sure why there is a connection between the wcadmin account and your user's ability to check-in work to Windchill.
I just accidently added wcadmin into View and print only group.
Try this.
https://www.ptc.com/en/support/article/CS20793
Temporarily disable permissions
xconfmanager -s wt.access.enforce=false -t codebase/wt.properties -p
Restart Windchill
Login as wcadmin and remove wcadmin from ALL license groups.
Reset the property
xconfmanager --reset wt.access.enforce -p
Restart Windchill
The article is no longer available
Yes it is. Refresh the page when an article throws that error.
Note: It may not resolve your issue since you assigned a license group. The fallback option in 11.x is to hack the LDAP (WindchillDS) and remove wcadmin from any license groups. I would restart Windchill after making this change to force the LDAP sync.
In 12.x and later, we decouple inside the database.
Hi @VL_5348599,
Anurag
