when i try to rename a file "You can only rename new objects" appears
ND_10940562
Initially posted in this topic
How can i rename a file. I did creat it, but i did check in/check out and then i noticed the name was wrong. But when i try to rename it appears "You can only rename new objects".
Yes, from the Creo Workspace, you can only rename things that are new to that workspace. Once checked in, you need to go to Commonspace or into the checked in item in Windchill to rename it. You can no longer use the rename in the workspace menus.
