where to select the process for a promotion request with api
Regular Member
I want to do a promotion request with API and it works with this:
https://www.ptc.com/en/support/article?n=CS133053
But within this request the process isn't selected well. If I do it manually the process is selected automatic, if I do this by API the process isn't selected. How can I add the process to the promotion request with API?
Re: where to select the process for a promotion request with api
Seems the process is in fact the workflow that should be followed. How can I do a promotion request by code (API) and link the correct workflow to the promotionNotice?
