I would like to know which version of mozila firefox can be used along with windchill 10.2 M030-CPS03.
If you are on maintenance, you can go here: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS99145&art_lang=en&posno=1&q=compatibility%20matrix&source=sea…
Hi Marco,
I'm not in to maintanance, we are getting upgraded to windchill to 10.2 and would like to know which version of mozila firefox supports it.
I couldn't access the link provided by you, as I my PTC account is of basic privilages.
Can you check the reference documentation? https://www.ptc.com/appserver/cs/doc/refdoc.jsp
For Windchill PDMLink, 10.2, Matrices - Software, it says Firefox 17.0.x ESR.
I got the information regarding it with the help of admin accounts which we have in our team.
As far the info i have from matrices, we can use mozila firefox ESR 24/higher.
Thanks to Marco & Patrick for the quick response.
That was F000. 10.2-M030 says ESR 31.0 or higher
Now i'm trying to install the latest version of mozilla firefox, as per the matrices higher versions are also supported. I will let you know the feedback once its been installed & tested for couple of days.
We have installed the ESR 34.0 and its seems to be working fine till now without any issues....
I think some of the upcoming releases of Firefox will has problems with NPAPI plugin support. https://blog.mozilla.org/futurereleases/2015/10/08/npapi-plugins-in-firefox/
Thank you
Binesh Kumar
Barry Wehmiller
