We are trying to have a Windchill 12.x cluster environment which can act as a fallback system as well.
Anyone with experience in setting a cluster.
We do have a single machine which is our production with WC 12.1.2.0 installed.
Ty
Raj
Refer this article - https://www.ptc.com/en/support/article/CS178451?source=search
In general, you would need to setup a slave server with the same config as master server & have all the required network ports opened between them as well as the properties for each node.
Database, Vault & Directory server (DS) would be shared between both the servers.
You would also need to configure DS Replication https://www.ptc.com/en/support/article/CS277472?source=search and so on. Good luck
TY
In our case, we plan to have 2 VM A and B
Can we have 2 method servers and 1 background method server?
If we have 2 method servers will both be foreground method server or 1 is just a MS and 1 is a Foreground MS
I did not get this part clear!
I did get that foreground handles all requests and background will take care of queues....
Any insghts - TY
You can have any number of MS & BGMS based on your server capacity. Refer this article - https://www.ptc.com/en/support/article/CS66035?source=search
Or you can have 1 MS/1BGMS & increase the heap size too.
https://support.ptc.com/help/wnc/r12.1.0.0/en/index.html#page/Windchill_Help_Center/WCAdvDeployGuide/WCAdvDepAdv_BackgroundMethServConfig.html
For setting heap size check this - https://www.ptc.com/en/support/article/CS26654?source=search
